monkeynuts
Your correct about the fuel filter, attached to the fuel pump inside the tank.
How exactly do you regrease that?So time for the 30.000km service:
Next up:
Clean and regrease the shock linkage.
Just take it apart, clean the bearings and stuff em with fresh grease.How exactly do you regrease that?
Took the rear shock out of the Husky today. Plan was to fit the original shockspring to the Duke R shock. But unfortunately the inner diameter of the original spring is 2mm smaller compared to the Duke R spring.
Shock will be going to a suspension shop for a service and a heavier spring.
While the shock was out I cleaned and regreased the shock linkages.
I'll take the forks out tomorrow. They will be going to the shop as well for some adjustments and a service.
While the fork is out I'll check and regrease the head bearings.
What difference are you expecting from a non dampened sprocket regarding the loosening?
