nampus
The Italian sprocket is dampened and with holes.
Any more info on this? A link to a webshop or a partnumber perhaps?
Indeed, but it also reduces vibrations.The damping of the front sprocket is to reduce chain noise afaik, and does not not dampen the sprocket movements...
Interesting. I will probably go that way. Thanks for infoI ditched everything, including the catch tube in the upper frame rail. Replaced it all with two mini DNA pod filters, directly on the crankcase and rocker cover vents. Been running it for over a year like that and totally clean.
Could you post some pics and maybe a a partnumber or link to the filters you used?I ditched everything, including the catch tube in the upper frame rail. Replaced it all with two mini DNA pod filters, directly on the crankcase and rocker cover vents. Been running it for over a year like that and totally clean.
I can't remember part number but think they were about 16mm female filters, I had already done SAS and EVAP deletes so it was just a case of removing all the other plumbing and fitting filters.Could you post some pics and maybe a a partnumber or link to the filters you used?
