champion rider
I treid one and it made my exhaust glow orange at low speed, so must have more flow, I took it off cause of that glowing.
Maybe with you set up it runs better?
I'll check them sometime in the futureCheck the cables of the old throttle assembly, could be that there is an intermittent brake !
I used the original bits from Husqvarna:Do you know the part number and/or source of the rebuild kit which you used?
Yes, so far I'm not very impressed with magura hardware.Ha! I had the same thing failing. At some point the plunger just becomes stuck and won't return. Replaced for the second time a few months ago. Once every two years...
A known issue on Magura HC-1 master cylinders. My buddy had the same problem on his SDR1290...
... and a fuel filter.
