Really interesting outcome....What setting were done on the adjusters before & after the swap ?
@Vatte 13mm shorter is quite a bit. Combine that with a softer spring and the bike will be very low at the rear. Are you planning to address that?The mounting lenght (356 mm) is only 13 mm shorter than the standard Vitpilen shock
What he said, you basically bought a shock that requires a lot of modification:@Vatte 13mm shorter is quite a bit. Combine that with a softer spring and the bike will be very low at the rear. Are you planning to address that?
For now I have plenty room to the costs of a nitron r3 shock to deal with the right ride height and maybe also another spring rate if not using the spring from the Vitpilens OEM shock.Here’s to hoping it will fit with that reservoir directly on the shock body.
It has the wrong length: 13mm at the shock will probably lower the rear by about 30mm.
It doesn't fit (bolt size and clevis width)
Wrong spring rate
And probably needs revalving.
And before you start modding it, please try to fit it first, just to make sure there is enough room for the reservoir and the preload adjuster hose. I was surprised to see how little room there was between the shock and the airbox when I replaced mine. I couldn't have the remote reservoir banjo face the airbox.
As to what @BISavage said, these links links lower the bike, while it needs to be raised.
