mainly i ride tiny curvy roads in the bavarian forrest. the roads are mostly in shitty conditions, because of cold winters, heavy vehicle (agrar and lumberjack).. there is no need to keep those tiny community roads in shape, because tourists and the main traffic are driving at the big national roads..
the andreanis doing good on those roads. At first i was worried, because somebody said, they are to harsh, you can only ride them on track etc.
it's nothing like that! and why should it be?! basically you get a set of springs for your purpose (riding style) and weight, compared with suitable hydraulic adjusters.
but now i have to improve my chassis geometry, because now i actully got some support at the front, wich i have to dail in.
the adjusters on the adreanis aren't much better as the stock ones.. they just do a good job.. but they have no separate highspeed lowspeed adjusters or such things..
i got a close look on the oem cartridge and those needles but i found no shitty parts oder major differences to the andreani ones..
in conclusion:
if money is no issue, i would buy nitron cartridge, because their bigger piston might have a slight advantage over the andreanis?!?
the andreani is a good cartridge, it works well, and you dont have to worry about springing and adjusters - but it's no show and shine one
if money is short, just buy some 9, 9.5 or 10 N/mm springs (depending on weight, riding style etc) and fresh recommended oil.. do a good service and grease up your fork seals to prevent stiction (check out dave moss). there is a good chance, that the oem adjusters arent as bad as everybody says..
the stock vitpilen suspension is unbalanecd for every purpose
maybe the front is good for commuting, but then theres a harsh rear. >>so you want a softer spring at the back
if you like to ride the hell out of it, you'll need much more support at the front.. >>so get harder fork springs
in springing you choose your game to play
hydraulic adjusters are just there to slow down/refine movement. they are not meant to give you major support!
imo best read for setting up a proper road bike is "the racing motorcycle, volume 3 by john bradley"
https://www.broadlandleisure.com/
