Max Kool
Not sure I can help you, I’m running a Nitron R3 shock.
That sounds perfect.10mm static and 40mm rider sag
Thanks for the reply, I guess I should have asked this before actually changing it. I could have saved half of the 10w for the next service.Nothing wrong with running different weights since each leg has a different “job”. Pretty sure multiple people on here did it and was what gave me the idea to do it on my bike, I want to say I did 7.5 in the compression leg and 5 in the rebound if I remember correctly but it’s been a little while…
Did you have to modify the Svartpilen spring in anyway? Also have a Duke R 2017 shock and looking for a stiffer spring. Seems to me that the Duke R spring has a 61mm diameter whereas the Svartpilen spring is 59mm.No , No , I have got a ktm duke 690 R 2017 shock , mixed with a Svartpilen 90/190 spring on my 2020 Vitpilen 701.
Great, many thanks! Is your weight with or without gear? I’m about 80 kg without and approximately 90 kg ”track day ready”.Not the spring but the preload collar has to be machined down 2 mm to fit.
and works just fine On a stock shock.
svartpilen 701 spring 90/190/59
preload 15 mm.
low speed comp. 20 clicks out.
high speed comp. 2 turns out.
rebound 15 clicks out.
free sag 5 mm. Rider sag (80 kg.) 35 mm.
works fine for me…..
