Elingsbo
Much appreciated, takes out a lot of guess work in choosing the right spring rate! Cheers.76.5kg nude in the morning , so in ful gear almost the same
So they are different, I'm not completely wrong about it.Sounds odd, there's like 7mm difference between the two...
Are you saying there's 7mm difference in cartridge length?Sounds odd, there's like 7mm difference between the two...
I had similar issues with mine. Almost impossible to stay on line in corners without decelerating, and running wide as soon as giving some gas. Plus had to turn the front adjusters almost all the way in to deal with massive break dive.Hi,
I'm new to this forum, but riding the Vitpilen for some time now.
Having no time to ride for a while I was thinking to convert my vit more towards fun Trackday riding without the constraints of tüv or whatsoever..
From my past experience with the vit on the track I've noticed that it's hiding it's obvious strengths pretty well. For a bike of this weight I felt it to be not very well turning, especially going into faster corners with less braking. At the exit of the corners I felt it ran away from me a bit, so I was struggling to stay one the line i planned to take..
So im thinking about pragmatic mods to achieve a very nimble machine, that's at least handling like my CBR600rr (pc40).. looking at the numbers it shouldn't be a big deal, right?
So what I took from reading through this is:
1. Change the fork oil to sae15 or 20 and also add additional oil to avoid hitting rock bottom under heavy braking
2. Lower the front by 10-20mm
3. Change the shock to a duke 690r one to make use of less stiffness and therefore more damping in the rear.. may be even getting a new one from hyperpro, nitron or so
4. Lifting the rear a bit to quicken steering (as by lowering the front) and increasing the ground clearance. Don't know how much is helping and when it's too much.
To my knowledge there are two solutions available to lift the rear with a standard shock.
Do you have further thoughts on this?
Kind regards
Nitron/Andreani/Hyperpro would cost me a fortune due to customs and exchange rates. Found a cheap 690R shock and let a local suspension tuner rebuild forks and shock. Hard to find compatible springs, so ended up with 6.5N in the forks instead of stock 6.0, and modifying the stock 110N spring to fit the 690R shock (I’m about 80 kg without gear). 3wt oil in the shock, and 485cc 5wt in forks. Together with a shims job, the bike feels much better. Sturdier under hard breaking, much easier to stay on line, and deals with track roughness without any drama. No change in ride height.
Have only had two track days since rebuild and haven’t ridden a proper sports bike on track, so can’t say how it compares to a 600rr. But way better than stock and can no longer blame the suspension for not being faster. Might still get away with complaining about the tires though![]()
