Geez it does look closer with the 800nk, does the pipe you’ve ordered have the bracket attached or loose?Dean, how loud is the exhaust; and do you ride it with or without additional db-killer?
I do like the CNC-milled end caps of the exhausts very much; the AR-laser engravings not so much.
I'm quite curious about the fittment of the 800NK exhaust; from my research it might fit even better than the Duke 790/890 exhausts; it's nearly identical, but the mounting point to the rear frame seems to be about 4-5cm more backwards.
There’s no mistaking the exhaust is loud, though now I’m used to it it’s not obnoxiously loud. I rode with the DB killer in for a few days, then decided to take it out to see how it was. I leave for work quite early (before 6am most days) so didn’t want to annoy the neighbours.. I am now in love with it, and honestly every time I ride it I wish the commute was longer, the noise is perfect!! I always loved the 270 angle crank but now this 285 is just heaven. I’ll never go back. I will one day look at the powerplate/air filter/ fuel x lite upgrade, but I’ll never remove the cat - it would then be too loud for me
