Hi all. I have this sporadic issue with my 2018 701 Vitpilen where the turn signals will stop working. When this happens, the dash light even stops flashing.
So far my limited investigation has led me to something being amiss in the wiring in the rear cowl. This morning while in fault, I had the bike on the rear stand with the cowl removed, I turned the ignition to on (without starting) and turned on the left signals (which weren't working) and I moved the large plug that had a green wire loosely wrapped around it. Just moving this plug and surrounding wiring seemed to have brought the signals back to life. According to the wiring diagram, this plug might be some option for an alarm system?
Has anyone had this issue before? Any suggestions on where to look from here? I have the official wiring diagram and it doesn't look overly complex, with only the relay (which I haven't bothered to investigate yet as its in an annoying location under the tank) and a 'diode' part of the circuit. But the behaviour noted above seems to indicate that it might be a wiring issue?
Thanks in advance!
Thanks in advance!
