801 owners club
Impressive
Agree! I'm still also very impressed of the 3M wrap; to me it was kind of an experiment; before I started, I feared it might become an absolute disaster with the quite challanging form of the covers; but instead it worked absolutely fine; and I can indeed highly recomend the 3M wrap.
You did a great job!
Does anyone else find the indicator switch a bit far away?
Maybe I have small thumbs, but I keep missing it, cant find it without looking when im riding.
And I have to change my grip and move my hand to indicate.
Yes me too! It's further away than my fireblade, I miss it sometimes too
Maybe of interest to one or the other; from "T-Rex racing" some new parts that will fit the 801 are available.
An update on this. I ordered the center stand.
If you are expecting SW Motech-levels of installation accuracy you will not find it. Unless I have a one-off left side foot peg mount this system DOES NOT FIT as shipped. It took a couple hours of install, removal, modify, repeat to get it to work. In the end I machined out a 3mmx3mm groove in order to get it to fit correctly:
That is the only pic I have, it was actually even more involved than that. It is entirely possible to follow their directions and install this system but it will wind up making that left side mount not sit flush against the frame and that is sketchy as hell.
Also, you will notice that in their pic they have their ugly underbelly pan on a Vitpilen. That is because the stock pan has to have a very large section cut out of it on the right side and a smaller (~15mm) notch cut out on the left. There is no mention of this anywhere on their website or instructions (which is a video to install it on a KTM 790 duke).
In the end I got it to work and it is solid, but a serious heads-up if you don't have access to carbide cutting instruments and want to install this. I still have to figure out what to do about the belly pan. The angle of the pic makes the retracted stand look like it hangs way down, it doesn't, it is tucked up nicely.
Husq factory welded the fuel tank slightly off centered. Bought the bike 2 years ago when it came out and husq hasnt come up with a solution yet. My dealer contacted them multiple times. Dealer tolled me they have to install a whole new fuel tank.
A bit annoying because i cant use the tank bag like this.
New to me ride destination, Sierra de Carzola. Circa 300km round trip. Sunny 25deg, hardly any other traffic. Lunch in Hornos (superb) and back home. I will be back.
Hello, I guess you are Spanish, I have bought the same model in yellow color.
They are giving it to me the next week, i have ordered the cruise control .
Are you happy with the bike? How about mileage, vibrations,...etc
Thanks and enjoy the ride safely!!
Hi @jacasado, welcome to the group.
Firstly, Im English ( been here ten years)
Secondly love the bike, there are a few niggles mentioned on the forum. Mine has developed the slight weep of oil around the gasket on the bottom of the engine. It’s very slight to be fair and an indicator failed which I replaced myself as it’s a four hour round trip to my not very competent dealer.
The bike has covered around 4500km in its first year. Gas mileage depends on how you ride 😉 It’s a very capable bike.
I like tinkering, so lots of modifications, Check out my profile.
Hope your dealer/garage is better than mine 🙄
Enjoy your ride
oh, thanks for sharing your experience, i will keep an eye on the gasket, seems to be an usual problem of this engine.
V´s
Remove the sprocket cover and get a flashlight. I bet the oil around the pan gasket is actually leaking down from the output shaft seal. I've looked a 5 different 790-engined bikes (3 dukes, 2 huskies) and 4 of the 5 have this weeping. Check your chain tension, run it looser than the spec, that was enough to make mine stop.
Hi @toast449 , not had a good look yet Tbf. There is a slight weep on the gasket on the other side to the output shaft. But it’s minimal.
The dealer over tightened the chain for the first and yearly services. Same tech, don’t trust them. It’s a multi franchise dealer in Murcia Spain. Fast in and out I’m afraid.
I cleaned the oil before my ride yesterday, need to check and clean the bike tomorrow.
Thanks for the reply
1000234513.jpg1000234513.jpgHas anyone tried replacing the bar ends?
I ordered these bar ends for the Duke 790 thinking they'd fit but the lock in mechanism with the brass piece isn't easily replaceable.
The silver spacers on the new lever, I tried reducing the size by removing one spacer but I'd need to remove the brass piece completely and hammer in the silver piece, but I risk making it forever stuck inside the handlebar.
Does anyone have any tips?
Thanks guys
I put end-bar mirrors on my Svart, so I had to remove them. I know, that is not an answer on your questions, just wanted to say, that you can live without them.
This actually helps, because my worry was about vibrations, any difference with and without the brass?
Thanks bud
