nampus
Looking good Max! That reservoir on the exhaust hanger looks a lot better than the frame mount!
It will stay cooler there as well
For length adjustment I would just bite the bullet and remove the linkage to adjust it.
For preload I always remove the rear brake fluid reservoir and then use a hyperpro preload wrench I pinched of my dad
I just put a rag over the frame tube there to avoid scratches.
But if your preload collar is a bit low, it might be very difficult to get to.
If all else fails, you'll have to take out the shock to adjust the preload
