801 owners club
With the radiator protection, I also ordered engine protection. Cost me 40€, all made in CNC aluminium
Clutch side
Alternator side
The left side fits perfectly, but the clutch side is a bit too far away from the engine. Could be 4mm closer but can do the job in case of...
Clutch side
Alternator side
Can you share where you got the CNC engine guards from, please? They look good
Had my second service today. 4300kms on the odometer since purchase in August 2024.
Service cost 139 Euros.
I also got the OEM Husqvarna Svartpilen 801 brake and clutch levers fitted. They look slick.
The clutch one is really short though. I can only get two fingers on it really. Takes a lot of getting used to.
Still toooooooo warm here in France to have a ride, so I build a stand for my disk lock with some carbon plates
View attachment 8681View attachment 8678View attachment 8679
Years ago I did something similar; and regretted it as dirt went into the likewise open keyhole of the disc lock and blocked it.
I needed a good amount of WD-40 to clean it enough to unlock it with the key.
Since then, I’ve been carrying the disc lock in the tank bag.
Anyone using lithium battery and any conplaints? There a few kg to save there I guess and I have found a cheap one available.
First thing I do on every bike is switch to a Shorai. 6 pounds of savings up high on the bike. The one in my MT09 is six years old and still cranking faster than a lead acid.
Any issues with the electronics of the bike?.
I have a friend that installed a lithium one on a vstorm and was the beginning of lot of problems
Has anyone installed Brembo brake calipers to replace the J.Juans?
I find the brakes the weakest point of the bike, a bit spongy braking so to speak.
I'm also considering to do it.
But first, I'll try to solve the brake problem under warrenty, then buy bigger disks (320mm) like Tom and only if it still not my taste, change to b
Brembo callipers.
