The bike will not run noticeable leaner just because you removed the db-killer, but the Euro 5 and Euro 5+ bikes are very lean tuned in general.
The 97° is the temperature of the coolant, not the temperature inside the engine; it's much higher.
I've read several articles and viewed several videos about the Duke 790/890 exhausts and tuning options (same engine like the 801).
It seems the stock Duke and also 801 mufflers are very good "performers" as the engine "likes" a muffler with some volume and some backpreassure.
With most aftermarket mufflers you'll loose some performance; especially with the very small mufflers.
The difference seems to be quite big; here a dyno graph of a Duke 790 with stock muffler and the Coober LM Ecu; with stock muffler and stock Ecu; with Ixrace muffler and Coober LM Ecu. With the Ixrace the bike lost 10HP and 6NM.
If the goal is to get an engine that doesn't run as lean as the stock engine, both solutions (the Fuel X and the Coober) seems to be fine.
But if you want to get some more (noticeable) HP and NM, you may need a proper custome remapping of your ECU.
