KTM abs dongle on Vitpilen 701
nampus
Netherlands
So after some discussion in this thread:
I came across a KTM abs dongle second hand for half price, so I thought, why not give it a shot.
I found the instructions for the dongle online, basically you should be able to switch functions by having the kill switch in different positions before you turn your key.
The instructions:
Full Street mode (ABS active on the Front and rear Wheel)
 Begin with Key in the “off” position.
 Engine Stop switch in the “off” position.
 Switch Key to the “on” positon.
 Move engine stop switch to the “on” position.
 Start Motorcycle.
ABS Mode 1 (ABS only active on the front wheel)
 Engine stop switch in the “on” position.
 Switch key to the “on” position.
 Start Motorcycle.
ABS Completely off
 Start Motorcycle
 Hold ABS button down for three plus seconds.
 ABS will now be completely turned off.
The dongle plugs into your diagnostics connector which you'll find under the seat unit on the right hand side.
This is the partnumber of the dongle I picked up:
I took of the rubber sleeve and stuffed it behind the battery:
And then it was time for a test ride.
As soon as you switch on the ignition you are greeted with the message: Not Legal on your dash.
Press the mode button and it switches to odo, trip etc, but you are left with the little triangle with exclamation point inside it on the right hand side of the display.
I had switched on the ignition with the killswitch in the on position which should be abs on the front wheel only.
As soon as I started moving both the abs and tc light went out, and a firm jab on the rear brake revealed that the abs on the rear wheel was definitely active.
Switching the bike off, kill switch off, turn the key, kill switch to on, start the bike, same result.
So as far as I could tell, supermoto mode (abs on front wheel only) does not work on the Vitpilen 701.
I then switched off the tc, rode around a little, switched the bike off.
Kill switch in the on position, switched the bike back on.
After I rode off, the abs light went out, tc light stayed on.
So the dongle remembers the setting in which the bike is switched off.
I then turned of the abs, rode a few miles. Switched the bike off, restarted, abs and tc both stayed switched off.
I always switch the bike off by using the key, I don't know what happens when you switch it off using the kill switch. I forgot to try this.
So the dongle does not work as stated in the instructions. But it does remember the tc and abs settings after switching the bike off.
If at any time you want to switch the abs or tc back on, just use the buttons on the dash to do so.
Happy to help 😁
And at €55 it was worth a try. If it hadn't worked, I would've sold the thing on without a loss.
The instructions:
 Start Motorcycle.
 Start Motorcycle.
ABS Completely off
 Start Motorcycle
I'm curious what year your bike is? Part of this thread is that it seems the 2020 701's can no longer manually turn off the abs via the button on the dash. I have a feeling you've got a 2019, right?
I didn’t know that about the 2020 Vitpilen, all I know on the Svartpilen (any year) you can only disable tc.
Really? I had read that ABS could be disabled, at least on the 2019 Svart 701: 1605079939231.jpg
I have a 2018 bike.
Don't know about the 2020 models.
I don’t understand you. All this dongle seems to do is remember the setting after you have shut down your bike (which I really want!), it doesn’t seem to enable modes the bike didn’t have before...
My 2020 Vit does enable turning off the abs. Just like disabling the traction control, also hold down on the “MODE” button to accomplish it.
Sorry if the answer has already been given on this forum or the other but I hardly understand english.
I would like to permanently desable the traction control on my Vitpilen 2019.
Is the 60312953000 dongle suitable for this? It seems to replace the reference 60312953500 that some of you have installed.
I also find an HQV reference for the 701 27012953000 (different beginnig) and I am lost !
Thanks for your help.
You could try the 60312953000, if it's listed as a replacement for the 60312953500. I only have experience with the latter one.
I have a 2020 Vitpilen 701. YES you can turn off TC and ABS manually, I do it everyday :(
I ordered part number 60312963500 today.
and........ The Dongle works on a 2020 Vitpilen. YES!
I'm happy to say with the dongle installed I can turn off the bike with the key and turn it back on and it remembers the TC OFF and the ABS OFF. Thanks Max Cool & Nampus
  1. Installed the dongle (5 minutes)
  2. Turned on the bike and rode 100ft, stopped, put into N with engine still on.
  3. Pressed the BLANK button and the SET button for 5+ seconds until "keep pressing" is no longer displayed. TC light is now on. TC is OFF.
  4. Pressed the BLANK button and the MODE button for 5+ seconds until "keep pressing" is no longer displayed. ABS light is now on. ABS is OFF.
  5. Rode bike and can confirm ABS front and rear off/ disabled and TC was also off.
  6. After a ten minute ride turned off bike with key. Took out key, put bike on side stand. Waited one minute. Started bike with key and the TC and ABS lights came on. It remembers the last setting. I rode it to confirm.
NOTE: It displays "Not Legal" on the screen when TC or ABS are turned off but that's kinda cool. Also with gloves on it's hard to press the buttons correctly. The buttons suck! You know your pressing two buttons correctly when the "keep pressing" appears.
