KTM abs dongle on Vitpilen 701
Not dongle related but maybe it helps to overcome the fiddly procedure a bit.
I figured out that you don't have to stop an shift to neutral. I drive away until a velocity I can coast as long as the TC switch off takes and only pull the clutch lever and do the procedure meanwhile. It's still annoying but at least there isn't any stop necessary.
I havent treid on the 701 yet...
What I did notice, is that they changed the software on the 401 sometime last year, and when I had the update mid of last year the first step was no longer necessary.
Meaning, after the software update the bike could be started and then before moving, you could just push the button amd the ABS turned off.
Previously the 401 also needed to drive and then stop; but this was no longer necessary after the update.
It was also noticeable that once the abs was off, pressing the buttons again displayed some error message which it also did not display before the update.
