DWB
I played around with the gearing as well - the std gearing is very bad and much too tall. I'm surprised they got away with this, as you have to drop into 1st for some riding that you should never have to be in first gear.
Tried with a 42t in the rear, and liked the change, so added in a 15t front. The rideability was a definite improvement, but the bike needed a 7th gear at speed. I tried this for several weeks, then accepted that it was now too short, and pulled the 42t rear and put it back to OEM 40t. (The biggest ratio change is to the front - swapping out the 16 for a 15 made a bigger change than 40->42.)
I think the 15t front and std rear is the best compromise of rideability vs. "higher speed riding needing another step up in gearing." Very happy with the change - still puzzled by Husky's std gearing ratio. It's very bad for low-speed maneuvering, esp in residential neighborhoods.
