To me there are a couple of reasons.
The stock brushed stainless steel Svartpilen exhaust is still my favorite; that's why I went to the relatively big effort to shorten the stock db-killer instead of simply changing the exhaust to an aftermarket exhaust.
At least here in Germany the officals are very sensitiv to decats; at vehicle spotchecks they always check the exhaust; and a decat is imidiately noticeble; while the shortened db-killer is only noticeble if you know it.
With a decat you'll need an addional Coober LM ECU; otherwise you'll get error codes; the Coober LM ECU also helps if you have a problem with the bike running too lean because of the EURO 5 restrictions; and also if you have a problem with stalling.
I never had any problem with stalling; possibly as I rarely ride in town; about 90-95% of my rides are outside of towns either on the highway or on country roads; and also on small backroads; nearly allways at higher rpms.
Finally the shortened db-killer instead of a decat was and still is the the very best option to me; and to me the result is absolutely perfect.
But you're right; I do indeed also like these kind of small, a tad challenging projects.
By the way; next to the Arrow decat, there are also some other alternatives with the necessary the third sensor plug available; for example also from Coober; and also from some other manufacturers.
