It depends on the "officials" in your region, but in my opinion it should be absolutely fine; the pre-muffler (catalyst) takes most of the loudness.
From what I've read, the Duke 790 / Pilen 801 engine "likes" a muffler with big volume and some "backpressure"; that's why you'll always loose some performance with the smaller (and also louder) aftermarket mufflers; the stock Duke 790 and Pilen 801 mufflers are very good performers.
With the stock 801 muffler and the small DB-killer you'll have still the same "big" volume and still some more backpressure; I don't know, if it'll make a big difference, if you'll delete the db-killer completely.
I also don't know (especially after my experience with the deformed aluminum spacer) if the coating of the black tip-cover is heat resistant and will take the direct heat of the exhaust gases if you'll delete the db-killer completely.
If you'll give it a try, report from your experiences.
