Suspension upgrade
animals21
Czech
Hi guys,
I really fell in love with my Svart801 and I know, that I am pushing the bike hard to its last horse ;o) There is something satisfying and fun to ride fast on "slow" bike.
From factory the Pilen is set to lowest preload on the rear and I think, that almost nobody during the reviews on YT, etc., set up the right preload. If you did not do that also, please DO IT, it really change the bike and let the shock work withing complete range.
With my 98kg naked I am almost on right SAG with max preload (just a little on the soft side). And the bike feels much more sporty. The front is without preload adjuster, but for my weight I am on same "almost on right SAG". So quite ok. Anyway I feel, for my riding style, that the suspension upgrade would help the bike. It is more an idea, because is not necessary. (for example I had Triumph Bonneville 1200 on complete Ohlins, brake discs and calipers from Brembo, etc ... even it does not make sense, because it still was a classic bike, even much sportier - surprising for some guys on supersports :ROFLMAO:, and not a sport bike).
I had really great luck for the price I have bought my Svart from the offical dealer, so there is some space in my budget.
There is no special type for Svartpilen in Ohlins catalogue. So can I take suspension dimensions for 790 Duke? I know, that front forks are better on Svart, not sure about the rear, but dimensions should be same???
Front forks inserts type
NIX 30 Street Cartridge Kit FKS 509​
Rear shock type
STX 46 Street KT 789​
Does anybody made this swap?
Thanks!
You don’t have compression setting on your fork? I am confused. I weight about the same as you, a little higher even and I think the fork is great.
I have no idea if a 790 fork will fit. The 801 supposedly has the same suspension as the Duke 990 but with different inners.
Sorry, but with about 76kg I definitely can't help with that... 😁
OK... I went the same way like you with my Harley XR1200; rear Ohlins shocks and front Andreani caridge kit; and also with the BMW ninet; rear Ohlins shock und front swap to complete Ohlins forks; and it made indeed a huge difference.
Did you also check the optional Husqvarna WP suspension upgrades that will fit the 801?
KTM Apex Pro 6500 Cartridge / 53182R81SET
KTM Apex Pro 7746 Mono Shock / 15180T91SET
Sure I have compression on my fork(s). But there is no spring preload.
I asked my dealer, so I will let you know.
This can be a good solution also! I will check!
Hi guys ...
I am back in thinking about new suspension. Firstly I had an idea to sell Svartpilen and buy something "more". But I end up with "there is nothing as good as Svartie in same price dimension" and find only 2 solutions - 1) buy Duke 990R or 2) upgrade suspension. I have more bikes and 990R will cost twice more than Svart and I still have the top class Tuono.
Long story short - I asked some companies and I am waiting to have all offers. Slight risk I see, that there is almost nothing directly for Svart. Is anybody sure, that what fits 790 Duke (any year??) will fit Svartpilen?
Thank you.
Oh, great. I would like to do mainly the rear shock. The 7746 should fit. I hope. KTM has it listed on their websites like Duke790/Svartpilen801. Looks like it is adequate quality as Ohlins STX46 KT790. I will see, if I can get some discount somewhere. I also quote K-Tech and ... eeeee ... the English one ... forgot the name ...
So what is new ... I got offers from Ohlins and WP. On the end it is a bit more expensive, than I expected. Ohlins is ofcourse even more expensive, but springs for my weight are in the price. In WP you have to pay them above normal price (cheaper a bit anyway).
On the end I decided to ask our quite famous Czech suspension guy (Tommy suspension) and we will make just springs for my weight on current stock suspension + he will make revalve. This will costs me, including suspension dyno, service, change-over, adjusting, test ride, adjusting 790€. Same service but with WP by him will costs 2530€, Ohlins + Andreani, excluding service works is around 2450€.
I hope that this will also help a lot, it is a quite budget bike, doesn´t make sense to me to invest so much in the suspension.
Never had trust in YSS and Hyperpro. I see them as low-end solutions and I am affraid, that it would be lower in the range than stock suspension. Maybe I am wrong, but ...
I have no personal experience with YSS, but many people are very satisfied with the suspension parts; and I have never heard anything negative about YSS; especially about the higher product ranges.
Probably depends on how the stock setup is.
I previously owned a Triumph Thruxton and the stock rear shocks were really bad. Even a cheap upgrade improved the experience dramatically.
So I picked up the bike from Tommy Suspension. On the end it was a more expensive, because I said “made the best from current suspension”. So he made - front and rear!!! - all valves new, some from higher spec suspension, some of his own production, in one fork was missing compression valve (not, that they forget, but as lower spec forks), new planchets setup, new oil, sealing, nitrogen refill, springs for my weight, etc. Setup for my ride style. Briefly - inside is top WP suspension spec now.
A made just 30mins easy ride and WOW! I was so surprised, how it works now, that I started to laught. Solid, but not hard. No squatting, no chaos, no diving, no corrections in curve needed. Feels also like +10hp/10Nm on motor.
Oh, the price, 1200€. Sounds cheap to me now after the ride.
This all was changed for better parts. I made 140km today on my favorite road and I am totally blowed away, FANTASTIC. I would say at least on the level of Duke 890R I had from my friend few days ago. Even better.
I test drove a 990R last weekend and that suspension is a lot better than on the 801. The brakes and the suspension are the only things I’d like to upgrade on my 801.
I am sure, that Duke 990R is a fantastic bike, but that is too much money and I love my Svart. So I decided to invest to the suspension.
With better suspension now, I can much more feel, that the brakes are not strong enough 😂 I have the EBC pads, but still …
Enjoy your new suspension! One thing usually needs to another.
The pulsating feel on the brakes really bother me.
Hi! I need your help. I have a WP APEX PRO 6746 shock absorber in stock in this configuration (photo). Do you think it will fit the SVARTPILEN 801? I can't check it yet, as my bike is still far away.
