Factory-Fit
Yes, £100 for the gadget, £100 carriage and taxes!Did your FuelX shipped from India?
I think what they mean is that it will adjust to maintain the set target fuel-air ratio. They both ( lite and pro) do the same, however the lite has 1 map which is set to a richer mix that stock, while the pro has 9 maps including 2 that are leaner than stock.Correct me if im wrong...but if the lite has 1 map that auto adjusts for the condition and modifications made to the bike, doesn't that make the 10 maps the pro has obsolete?
I contacted PowerTRONIC and they said the lite would be equivalent to map 6 on the proI think what they mean is that it will adjust to maintain the set target fuel-air ratio. They both ( lite and pro) do the same, however the lite has 1 map which is set to a richer mix that stock, while the pro has 9 maps including 2 that are leaner than stock.
What that fail to specify is the actual ratio for each map in both version and and where would the lite map be between the maps on the pro.
I can't testify to numbers, but I installed one of these and since my bike has been running cooler, smoother and makes almost not popping sounds on up or down shifts.
My exhaust is stock with a Werkes slip-on.
Would you post a picture? I don't have mine.I contacted PowerTRONIC and they said the lite would be equivalent to map 6 on the pro
The fuel ratio ranges for the maps are listed in the user manual
I don't have one yet so I looked up the manual on the website and that version didn't have the AFR ranges, I am trying to locate where I saw it online before and will post if I find it again. That said, I went ahead and bought a Pro version today as I just installed the Coober cat delete, and don't want to run the risk of leaning the bike out.Would you post a picture? I don't have mine.
Got it. I remember that the manual I got didn't have the ranges. That's why I'm interesting on getting them, just to know.I don't have one yet so I looked up the manual on the website and that version didn't have the AFR ranges, I am trying to locate where I saw it online before and will post if I find it again. That said, I went ahead and bought a Pro version today as I just installed the Coober cat delete, and don't want to run the risk of leaning the bike out.
found it, the person that posted this said it came from powertronics supportGot it. I remember that the manual I got didn't have the ranges. That's why I'm interesting on getting them, just to know.
Good point about the ECU adjusting long term mapping. Plug's fine, I checked, also tried an NGK Iridium but back to factory-fitted Bosch now; Before first service from new the bike started intermittently and violently misfiring in a jerk-jerk fashion, it was rescued by truck under warranty but UK dealer (Appleyards at Keighley) could find nothing wrong. Returned after being plugged in, ran OK for a while, requested Dealer activate Quick Shifter after it wasn't working after first service. Later had engine OBD display on, the 'Quick Shift Failure'. Both cleared after kill-switch and restart, mailed dealership and Husqvarna UK, awaiting response. Misfires etc all happened before test-fitting the FuelX lite, it is a good product but staying off until other issues resolved, will refit after warranty expires.What do you mean by misfiring, did your fuel-x faul the plug?
I am no engineer, maybe via long term o2 sensor data the ecu shifts map fueling![]()
I just ordered mine,I will hopefully have a good review once it's here and installed.Pretty affordable- 160 for the lite and 180 for the pro
The lite has 1 autotune map
The pro has 10 autotune maps with a handlebar switch to change maps on the fly
Plug N Play Performance ECU - PowerTRONIC
PowerTRONIC Plug-In performance ECU is a Fuel Control+Ignition Control+Quickshifter module right out of the box. PowerTRONIC ships world wide!powertronicecu.com
Kind of makes sense since the bike only enters closed-loop when the engine is warm, right?I installed the FuelX Lite and the K&N filter today (LV10 already installed).
I don’t know… at first it felt like always, then after a few minutes at low speed I felt the bike wasn’t so sensitive and jerky. I have never had an issue with stalling or jerkiness before but it felt smoother. Downshifts also felt smoother. Then I started to pressure the bike a little. It felt like the bike was flying when I pushed it. The placebo effect is strong I guess. I have no idea if this these things does anything or not but it sure felt good during the short test ride.
Alright, so here's the deal.I fell down a rabbit hole. Started googling cat delete, then ECU, then found lots of info on the Fuelx and ended up here.
One question though. I’m no engineer but opening the bike up with K&N and LV10 should be a good combo, right? I’ve seen some YouTubers using BOTH the vented air box lid and K&N filter. Wouldn’t that just result in too much air if not using an ECU?
