Yes there are some, most have the wires for the number plate light and indicators exposed tho. Explore the full Fender Eliminator postDamn. Yes. It will need a whole new base plate with 4 holes. I was hoping to avoid making something myself (with my limited skills!)
Is there no off-the-shelf solutions for the Husky 801?
Hi TomHi Yonsson,
here also a pic of the backside of the baseplate I fabricated.
I adapted the plate directly to the recess on the rear frame.
Yes, I also made a sketch of the plate and can scan it.
But the plate needs to be beveled on all sides; one side quite a lot.
Alternatively a plate can be fabricated without the bevels; but with bigger gaps; it would definitely be more simple.
Here also (again) the photo of the recess on the rear frame.
You'll notice, the gap between the two parts of the rearframe isn't perfectly straight.
So the boreholes for the countersunk screws in the baseplate to mount it to the rearframe may not fit 100% on your frame.
Maybe standard Inbus- or Torx-screws instead of the countersunk screws (with a tad bigger boreholes) are a better solution if the plate is not fitted directly to your bike (that's what nearly all manufacturers do).
Hi Tom
What would be the simplest way for someone with limited technical skills to make a base plate like this. Would you be able to send me your drawing files please? I will have a go but have limited tools. Even if I could make a base plate with no bevels but a bit smaller, that would be fine I think.
Thanks for any help!!
 www.motoblouz.com
					www.motoblouz.com
You're welcome!Thanks Tom - and for the quick reply, too!
Of course, thank you for letting us know Tom.
@Tom , You have made a few different versions now. Which one is your favorite?
I think this a good option for most people.
