Were the cracks at the bolt holes or the 90° bends? The mig should fix that if it happensInterested as to whether those ones get cracks from the vibrations like the original ones.
I spaced it out so that they stand about 2mm off the casings, I also finger tighten bolts with spacers to make sure I would not strip the threads bottoming the bolt. Yes not to sure if I will keep them onSounds like my estimate of 6mm was about right then, though I'd thought mostly 45mm bolts, with one 50mm and another 55mm. That was based on the originals at 35mm plus the extra from the spacers.
I'd also thought I might want them to sit slightly off the engine casing as the screws to hold the outer covers on stick through a little further than everything else and I wouldn't want them scratching the casing. Looking again though, I think the screws sit at a point where the casing is recessed. See pics below where I'd used the included spacers to get another 5mm.
All in all, I'm not sure I want these on my bike now! I guess they might stop the odd chip from stones, but not much else. That said, I'm not really sure how much protection the originals are supposed to give.
