Engine protectors, Chinesium
dakaroo
Peso of the North, Kelowna BC
Look what arrived in the mail cover protectors for my 401. I will post update of them installed.
Cost was 11.66 plus shipping total of 31.21 CDN.
They look okay
I'll be interested to see how you get on with those. I ordered some & found they were out by quite a lot & needed extra spacers for each mounting point around 6mm. I did some testing & measuring and am now debating whether to buy some spacers & longer bolts.
If you look at the picture the kit came with shouldered spacer, the clutch side had to thicker spacers to make up for deepth diferrence on 2 bolts. Having said that I'm off to the hardware store for about 3mm more in spacers...
So I was able to fit these, the only draw back was the additional hardware cost almost as much as the guards I needed 7 of 6mmX50mm and 1 6mmX60mm bolts to get the clearance from housings and many packages of 6mm spacers. The hardware that came with guards was only about 4mm longer than factory. I may replace the multiple spacers with solid spacer, looks? Oh well at least I could play with it -4°c 🥶 Can't wait for the dog days of summer 😎🏍
Sounds like my estimate of 6mm was about right then, though I'd thought mostly 45mm bolts, with one 50mm and another 55mm. That was based on the originals at 35mm plus the extra from the spacers.
I'd also thought I might want them to sit slightly off the engine casing as the screws to hold the outer covers on stick through a little further than everything else and I wouldn't want them scratching the casing. Looking again though, I think the screws sit at a point where the casing is recessed. See pics below where I'd used the included spacers to get another 5mm.
All in all, I'm not sure I want these on my bike now! I guess they might stop the odd chip from stones, but not much else. That said, I'm not really sure how much protection the originals are supposed to give.
I spaced it out so that they stand about 2mm off the casings, I also finger tighten bolts with spacers to make sure I would not strip the threads bottoming the bolt. Yes not to sure if I will keep them on 🤔
