Black Arrow
In case anyone had an interest in putting a battery maintainer on their 401
A pretty simple DIY for those that don’t put a lot of km’s on their bikes. With the cold weather coming and this being my 3rd vehicle, I figured I should get this done.
1. Unlock, remove rear seat section, front seat and then the battery cover.
2. Disconnect negative (black) wire from terminal, pull safely away from terminal. Then, disconnect positive (red) terminal, pull aside. 10 mm socket for both.
3. I installed CTEK comfort connect (quick connect) wires to terminal, in reverse order to above. I.E. positive (red) first, then negative. I couldn’t find torque specs on battery terminal screw bolts, so I went with tight. If anyone knows the spec, please let me know.
That’s it. The connector sits under the rear section of the seat. So once I use the key, pop the rear seat section there it is - the quick connect takes a few seconds to connect / disconnect.
