JCON
Can anyone tell me if the Vitpilen 701 uses the same size Triple-Tree as the Vitpilen 401?
Ah. My issue stems from trying to install risers (Gilles Tooling)...The bars don't appear to be the same diameter on the 701 as they are on the 401?
That was my thinking as well, unfortunately, there's no way this set of 32mm riser is going to fit snugly in the 22mm cone-shaped hole of my vitpilen 401. $300 later and a bunch of european sass...I guess we'll see what happens when i receive the longer bolts I ordered to circumvent european engineering excellence.![]()
That's right the Gilles risers don't fit the 401. But there are many riser options for the 401 out there.
e.g.:
More details you can find in this thread: https://hqvadventure.com/forum/threads/passenger-comfort-2021-vitpilen-401.821/![]()
KTM 390 & Husqvarna Svartpilen 401 1 3/4" Pivoting Handlebar Risers fo
Made in the USA 1 3/4" (44.5mm) Center-to-Center Rise Pivots Backward/Forward based on Rider Preference 26mm Stem Accepts 26mm Handlebar Will NOT on the SMC-R!! They have a different bar diameter Always check and confirm that your machine has adequate cable and brake line length before...roxspeedfx.com
thankyou, I was about to lose it.Those are for Svartpilen.
Great. What is your return policy?On May 30, 2022, at 10:56 AM, Ralf Kahllenberger <R.Kahllenberger@gillestooling.com> wrote:
Hello Mr L.
this item does not fit the 401, it is only suitable for the 701, I am sorry.
Best regards
Ralf Kahllenberger
GILLES Tooling
This is all great stuff, but can any one tell me why the riser fits the 22mm insert on a 701, but not the 22mm insert on a 401? Also, why does GILLES tooling not make this discrepancy clear on their website??!?
