Here some more detailed pics of the small luggage rack made from the optional pillion seat cover.
The loops are a first mock up with some straps I ordered to fabricate the final loops to attach my Kriega bags.
It's still work in progress.
Up to now no photos, but here some sketches made from some pics from the owners manual.
At all I used 5 straps.
The two loops at the front are attached to the frame on each side underneath the front seat.
The two loops at the rear are made from one single strap, that is attached with two seperate straps to the frame on each side underneath the pillion seat.
With the pillion seat the Kriega straps worked fine; just with the pillion seat cover these simple (grey) custom made straps work better (the black straps are still Kriega straps).
Here also two additional pics from the fabrication.
I did the bending at the rear before cutting the outer contour and adding the slots.
I used a steel pipe with the same rounding like the rounding of the pillion seat cover to shape it.
To fabricate the slots, I drilled the holes at the end of each slot and simply cutted the slots between the drilled holes with a saw.
Afterwards some filing and sanding.
