A small luggage rack made from the optional 801 pillion seat cover
Tom
Germany
Here some more detailed pics of the small luggage rack made from the optional pillion seat cover.
The loops are a first mock up with some straps I ordered to fabricate the final loops to attach my Kriega bags.
It's still work in progress.
Now with the final loops (strapped to the frame); for testing the Kriega US 30 combined with the US 20; together about 50 liters capacity.
Any photos of attachment point for the loops?
Up to now no photos, but here some sketches made from some pics from the owners manual.
At all I used 5 straps.
The two loops at the front are attached to the frame on each side underneath the front seat.
The two loops at the rear are made from one single strap, that is attached with two seperate straps to the frame on each side underneath the pillion seat.
Thanks! I'll have to pick up some straps and give that a try.
With the pillion seat the Kriega straps worked fine; just with the pillion seat cover these simple (grey) custom made straps work better (the black straps are still Kriega straps).
Here also two additional pics from the fabrication.
I did the bending at the rear before cutting the outer contour and adding the slots.
I used a steel pipe with the same rounding like the rounding of the pillion seat cover to shape it.
To fabricate the slots, I drilled the holes at the end of each slot and simply cutted the slots between the drilled holes with a saw.
Afterwards some filing and sanding.
@zeno feel free to copy it; it's not too difficult; you'll just need an aluminum plate and some proper tools... 😁
@zeno It's attached to the pillion seat cover with four black countersunk stainless steel bolts with washers and nuts.
hey @Tom any willingness for a made to order yet? beautiful work!
Edit: or if possible a pdf like the tail tidy plate you did so I can bring to fabricator
Thanks @Braxchat
I'm absolutely fine with sharing some ideas, but I don't make parts to sell them. As they are entirely handcrafted, it's simply way too time-consuming.
I'm sorry, but I also can't help with the PDF. I just created a rough sketch of the design idea and then fitted the aluminum-plate directly to the pillion seat cover.
