Beautiful work! So neat and stylish.
Do you have a link for the tail tidy please?
Any chance you have the dyno results? Just curious.
Butt dyno and viking blood isnt much to go on.
Maybe the turn light should be integrated in the rear lightTo me it's more kind of a design "weakness" from Husqvarna.
What surprises me more is that so far no manufacturer of tail tidies has succeeded in developing a truly attractive and technically fully functional tail tidy.
If the indicator is placed at the right position (high enough), it also works with the stock exhaust and also the stock indicators; maybe even without a heat shield at the indicator.
The adapted 1290 tail tidy works absolutely fine; maybe it would also work even without the added heat shield.
www.rizoma.com
Hi, this is some 3d print or where did you get this tail tidy solution? Thanks!Here the summarized pics of how a custom made heat-shield to protect the indicator / turn signal at the muffler can look like.
They are some aftermarket Duke tail tidies that are adapted to the 801.Hi, this is some 3d print or where did you get this tail tidy solution? Thanks!
I hadn't thought of this and it is obvious! I have some m-blaze Motogadget ones I may try. Will need to investigate the resistors and would like to get proper KTM/Husky terminals to make them plug and play if possibleThe solution is to buy mini turn signals that fit deeper into the exhaust.
Remember that they need resistance to work, otherwise the error will appear on the display.
I recommend the Rizoma EE164H
Indicatori di direzione per KTM 790 Duke (2018 - 20)
Kit cablaggio con resistenze per indicatori Rizoma per Ktm 790 Duke: ogni kit comprende 2 cablaggi. Acquista su Rizoma.www.rizoma.com
