801 owners club
I bought the front light .. eh ... protector (???) and looks great I thing. What is not on the photo, I install the original tank grips and works GREAT! Must have!
The foam protection on the handlebars made much more noise into the helmet, so I threw it away.
I did the mod to remove the decibel killer in the Akra today. Very simple job. Need to find something to cover the hole up on the inside tho.
I also ordered the Coober ECU to try clean up the fueling at low revs. Should be here next week.
I wouldn't have predicted it but I love the bronze wheels. That with a British racing green tank and front fender would look amazing.
Since your photoshop skills are much better than mine can you try my tank color on your bronze wheels?
Yeh I have one of those in my basket. However it’s for a hole in the carbon end cap. Think I need something metal to deal with the heat
This is what akrapovic uses for holes in carbon end caps 😅
images
A simple short round head screw will work; but it will need a nut.
So, the Coober ECU turned up today. No installation instructions but I’m sure I’ll cope. Won’t get chance to fit it until later this week.
If you check my YouTube video it might save you some time. Installation should be pretty much the same except that the Coober has 3 connectors.
Thanks bud
Thanks bud
Managed to fit the Coober this afternoon. Very straightforward, getting the wiring nice and neat took the longest time. Fitted it all to try first then played about making it look good. The ECU unit itself fits on top of the airbox lid on some double sided Velcro tape. I removed the sticker with the fuse box info on and put onto the ECU. Think it looks quite tidy. Now the good bit, zero problems on start up, think the tickover is slightly higher. The hesitation and hunting at low revs has disappeared and it’s much smoother now. I only managed a very brief run but first impressions are excellent.
