blue_monkey
Yikes. Bit of a design fault the positioning of the exhaust. Although Husqvarna would say that we shouldn't put on tail tidies!
And that’s why short exhausts is a good idea.Yes, it seems the Remus is even a tad longer and higher than the stock exhaust.
If I remember correctly, the connectors are sealed.I'm curious what others have done with the exposed wires after installing the top block or mizu fender eliminator. Did you use heat shrink electrical tape or just leave it alone?
Do you also have a pic that not only shows the bike, but also (and more concrete) the tail tidy with the indicators?I got this De Nigro Racing one, it's not that great. In any case, the original indicators end up in front of the exhaust, I had to get smaller ones and their brackets.View attachment 8642
Thanks! It doesn't look too bad; the angle of the registration plate seems to be quite flat; and how about the registration plate light?
no, i'm outlawIs it in Italy "OK" without?
Otherwise maybe you could ad one of these super tiny "Highsider" SMD-registration plate lights / they are even e-marked.
If you hit a heavy undulation that rear tire is going to grab the reflector and yank it off. When I did my tail tidy I had the license plate too upright and the bottom of the plate got rolled under (and I'm in the US, our plates are a lot smaller than yours)
