Fender Eliminator
Yikes. Bit of a design fault the positioning of the exhaust. Although Husqvarna would say that we shouldn't put on tail tidies!
Yes, it seems the Remus is even a tad longer and higher than the stock exhaust.
Don't get the mizu tail tidy. My guess is they thought the KTM version would fit the same
Damn, that's quite a lot offset; that's strange; there are some more 801 with the Mizu and up to now nobody reported about a problem.
I'm curious what others have done with the exposed wires after installing the top block or mizu fender eliminator. Did you use heat shrink electrical tape or just leave it alone?
If I remember correctly, the connectors are sealed.
If it's just for a cleaner look, you could use some braided hoses.
I already used them on other bikes and they work fine.
I was pretty disappointed with the Mizu as it was still pretty long, so I cut it shorter and cleaned up the wires. I also had to use the original plate light. The Mizu was having connection issues. It doesn't look too bad.
