toast449
I wish I saw this sooner. I was going to move to the Nitron but I hate that baby blue, I had no idea you could get it in a dark spring. That is getting ordered this weekend.
Honestly I had an Öhlins on my Hornet 600 and this is better quality. The machining is to notch and you can remove the spring by just turning the preload.I wish I saw this sooner. I was going to move to the Nitron but I hate that baby blue, I had no idea you could get it in a dark spring. That is getting ordered this weekend.
Hey Jester,No a complete new shock from Nitron.
I had looked into changing springs but there are no companies doing just a spring here in the uk. I found a company, Faulkners, that make springs. They make a 58.5mm internal spring in the length needed (180mm) for the WP rear shock. These come in various spring weights but I would be guessing on the actual weight needed for me. Also I would need some sort of spring compressor for bike shocks and may need to buy several spring to get it correct. There are a few people on forums that have changed springs on Husky and KTM rear shocks but the actual spring weight vary so much that I could not use their experience in a reliable way. There are 2 people on this forum who have changed springs, one is 95kg iirc and has fitted a 107nm spring the other is 75kg iirc and has fitted a 130nm spring. Both report great results!! Also people have fitted 1999-2002 Yamaha R6 rear shocks with modifications. I think this is a definite step backwards, the R6 had a 90nm spring weight! Any 1999-2002 shock would need a full rebuild then a new spring also making the price ridiculous for a 22 year old shock, even if you found a really nice one to begin with.
Nitron will make the shock with a spring weight specific to my 95kg. Only problem is the £560 price tag. When my shock arrives I will post the spring weight on here. My guess is it will be around 140-145nm, time will tell.
Thanks for reading, Jes.
At nearly £700, no I have found the spring upgrade and good quality oil has sorted the front for me. I originally had no intention of changing the suspension but found the WP shock really quite cheaply made and the damping too much for the spring. The forks are better quality, though not by much. The fork springs are where the most change could be felt. Changing to a Linear spring from the standard progressive ones made a massive difference. My bike now sits higher both front and back. I have now finished playing with the damping (front and rear) and I am very happy with the handling now.Hey Jester,
Did you consider this Andreani cartridge kit? I know it’s vitpilen but aren’t they essentially the same?
Husqvarna Vitpilen 401 2017-2019 Andreani Misano Evo Fork Cartridges (WP 43 mm) 105/HQ2E
Andreani Misano Evo fully adjustable fork cartridge kit for the Husqvarna Vitpilen 401 2017-2019, WP 43 mm fork. Replaces the OEM fork internals, adding independent rebound, compression and spring-preload adjustment, with a 20mm piston and linear springs matched to your weight.Built to order. TW...twsuspensiontech.co.uk
That really is so much better. I keep telling myself I will turn one out of aluminum on the lathe but just being dark makes a huge difference. Link?Just a little mod to remove the horrible rear brake reservoir, it was more the colour of it really. Anyway, a new tiny one from eBay and a new bracket and it blends in nicely.
Same original hose but with the slightly larger clamp from the kit. I filed the hole in the lid holder on thing to still hold this new lid on. Works fine and holds plenty for a rear brake. Thanks for looking, Jester.
I just put rear brake reservoir into eBay search and picked the cheapest. £4.91 here in u.k. people buy these from china and then sell on eBay so it came in a couple of days.That really is so much better. I keep telling myself I will turn one out of aluminum on the lathe but just being dark makes a huge difference. Link?
Quick update, I ordered a 42 teeth Afam rear sprocket a while ago and because I had some downtime after a hand operation I fitted it to test the difference. Well I like the slightly milder acceleration, it goes through the gears at a slower rate now. I always felt that the gearing was a little off, like too much low down and this change of rear sprocket seems to help. I no longer really use 6th gear on the backroads unless there is a long straight between bends, I sometimes just snicked it to 6th for a few seconds before going back down to 5th before another fast bend. I can easily sit at 70 mph on main roads whereas before it felt a little revvy.!! The quick shifter also works a lot smoother and for the first time I can use it on downshifts under 5000 rpm and it feels smooth, not like I just crunched it into gear. I fitted a new 15 teeth front sprocket at the same time as the original was showing wear in the rubber Dampener. I did not change the chain as it is well within specs, length wise and barely shows any sign of use. Anyway I reckon with the better quality front and rear sprocket over the Indian one that it came with and the DID chain I already changed, will last as long as I have the bike.
Pics..
I used the original chain length so flipped the adjuster block to keep the bolt a bit shorter. There is about 12mm of space for the axel to slide backwards left, so should be more than enough. I have also gained around 15mm of wheelbase, which is a small win.
Thanks for looking. Jes.
I only use first for pulling away or really slow manoeuvres in traffic which I barely ever drive in. I cannot think of a corner where I ride that second gear would be too high of a gear. We have no switchbacks here in my area of the UK. The last time I was out I noted the revs at 70mph in 6th gear at 7000rpm, I am now at 6250-ish. I ride through a lot of rural villages which are 30mph speed limits, I ride them at 35-ish and that was in 4th gear, as I exit the 30 back to 60mph speed limit I did not have to change down to accelerate back up to speed. Now I use 3rd for the same roads, I can stay in 4th but it feels more laboured.You increased the gearing, made it taller.
I rather like the stock gearing. It's much taller than on my previous bike, CB300R. On the CB first gear was pretty much useless, too low. On the Vit I can make good use of first gear on tight switchbacks where second gear is a tad too high. I'm finding that first gear is much more usable after I installed the FuelX, less snatchy.
I rarely use 6th gear as is but I did spend some time on the freeway three weeks ago and I thought it was plenty high. I was going 70-80 mph. I use 6th gear so infrequently that I almost forgot it was there, lol. On the CB I used it a lot.
I find the quick shifter works better the higher the revs. I never use it for the 1-2 and 2-3 shifts if I'm not hard on the gas, revving it out.
Sorry but I would put in a link if I knew how but I am not good on tech.Obviously there's a difference in the roads we ride. Mine are tight and twisty mountainous canyon roads.
I'll watch.Sorry but I would put in a link if I knew how but I am not good on tech.
If you are interested in the types of rubbish roads I ride and have some time to kill there is a video on YouTube, just type in “riding motorcycles in Suffolk” it is the one titled “do you always ride like that” or “keeping it smooth”. It’s 40 mins long and for the most part It is not exactly where I ride but very similar. You can fast forward it and it all looks similar. It is not me obviously and I am riding much faster, mostly but same type of rubbish roads.
For the record I love watching American canyon, coastal or mountain riding. Some of it is very fast and flowing and would be the roads and weather we dream of here in the UK. Most comments from UK riders are “wish we had roads like that here” etc.
So quite a bit has happened since last year. I have gone back to standard gearing (15/45) albeit with better quality Afam rear and a new rubber dampened front. Bike is now back to Hooligan antics and I think I prefer it with more acceleration and can live with more revs at higher speeds.
I can recommend the 'Comfort Seat' from Husqvarna Technical parts. Even at £145 it is not as soft and for my Butt is more comfortable being stiffer foam. It is also not as slippery as it is like a 'Jeans' type of material in the center.
I have also now gone to Bridgestone S22 (140-70-17) tyres and they are very smooth. They take more to warm them up than the Pirelli STR' as it is barely 15C here in the UK. When summer gets here I am sure they will warm up faster and my initial thoughts on grip once warm are looking good. Probably 'over-tyred' for such a small bike with no power but I wanted to try the 140/70 rear and these were good value at £200 for the pair.
Pics of tyre with around 100 miles on, all scrubbed in.
I have also managed to finally get a Galfer disc for the front. After changing to EBC HH (with the standard disc) the braking was slightly improved. I did around 60 miles with the standard disc and HH pads before fitting the Galfer wave disc this morning. After a short ride this afternoon doing some repeated heavy braking I am impressed with the new disc pad combo. I have mentioned before I use engine braking a lot so initial bite is important as I am not constantly keeping heat in the brakes.
pics of disc fitted.
ABS ring is silver so might have to be painted black at a later date, I'll live with it for a while first.
Pic of bike now hopefully finished.....
...it will never be finished, they never are!
So with my sticky new rubber and single finger brakes, I am set for a great summer out on the rural roads of Suffolk UK.
See you out there....
Thanks for looking Jes.
Nice work! What's that little bag you've got on the back?So quite a bit has happened since last year. I have gone back to standard gearing (15/45) albeit with better quality Afam rear and a new rubber dampened front. Bike is now back to Hooligan antics and I think I prefer it with more acceleration and can live with more revs at higher speeds.
Thank you. We half 5 days of 15c (near 60f) dry weather here, I had to wait a couple of days for the roads to dry out but managed 3 rides before it went back into winter. The roads are very greasy where they are damp as there is still some salt around, very scary on new cold tyres. Managed to get them up to better temps and got the tyres bedded in before the weather changed though. Bring on the spring.Looks boss! Glad that you are able to go out and ride.
I rode last Sunday and I was thinkin' that gearing it DOWN might be better for the roads that I ride. I am not using 5th and 6th gears much.
Thank you, I have a FuelX and it’s wiring under the seat so this has layers of foam cut for various tools. Also here in the UK if you have a rear seat you must legally have rear foot pegs, I have deleted mine so needed to cover the rear seat. I can also put my phone in on its side and record lean angles, braking and acceleration forces using the Pirelli app, not that I would do that sort of irresponsible thing on the road, honest officer!!!Nice work! What's that little bag you've got on the back?
