Harold J.
Hi All,
After a few reaction posts in other topics from me, i did find the time for a short intro of the "my new to me" privately acquired 2020 model, 2021 first reg 701 Vitpilen (you all know how that model looks like ;-) )
i bought it with a A2 mapping on it deployed.. (KTM germany) i was quite suprised how quick it still pulls, but it quits rather early with the torque (as you will see in the attachment)
first we uploaded the standard 55Kw mapping, adapted that one after a few dyno runs and added a Rapid easy, see under the graphic, why
i did a few, rather small Hardware mods, like SLS removal, but kept the catalyst, both for function and noise (europe is not the best area for too much noise these days) and the effect on performance for street use is minimal in our experience...
the muffler is an aftermarket unit, titanium 45cm long (long is gooood for power and a low noise)
i also did change the HC1 cluch lever for a longer one, to my taste the Vitpilen standard one is too short and Magura do have a longer one in their catalog
time for some images..
first the clutch lever:
before / comparison
Before:
And after:
And the dyno runs in one graphic together for comparison
End result : 80,8 Nm and 77 bhp
we changed / adapted the mapping in the original ECU, but KTM does not allow to change the values in the close loop areas
so for those areas a Rapid easy was used you can see the results... no need for extra mods ;-)
regarding AF, the RED line is the one we managed to deploy
IMHO there is no "out of the box" solution, as each bike is different, Hardware changes do matter even tiny ones..
before someone asks... simple and cheap Decats do not bring much for street use IMHO and if you do it, you need more extensive remapping and a more expensive (Rapid) unit... (the "old" Power commander 5 is phased out, the 6 is too limited and expensive therefore) as said "out of the box" is not a great solution IMHO
cheers
Harold
before / comparison
Before:
And after:
cheers
Harold
