Vitpilen 701 vs Indian FTR 1200
Max Kool
City of Angels
Since someone asked, here's a writeup I did a while ago when someone asked the same question.
First the FTR1200. It's very light steering bike for its weight, good brakes, smooth gearbox (on mine at least) and a monster of an engine! That torque!! it's neigh on impossible to underrev this engine, and the first few rides I actually rode it a gear too low. Howling engine dropping into corners, which due to the torque is totally unnecessary. Everytime I ride it gives me the widest grin. Ergonomics are perfect for a 5'10" to 6' rider, everything falls into place, good quality switchgear and a very clear dash. The only time I feel the weight is when I roll it out of the garage. It's a do-it-all bike. City traffic, canyons, freeway, it really doesn't care. The FTR hardly required any changes for me to make it perfect. Apart from aestetic changes (tail tidy!) about the only thing it requires is a decent tune (ECU flash). Ryan Randall from Indian of Charlotte is the king of the FTR and I haven't heard any negative comment about the work he does. Highly advised, and yes, if you live anywhere else in the world, he can set you up remotely.
Now the Husky Vitpilen 701. Tall seat, taller than the FTR. Again, perfect ergonomics for a 5'10" dude. It has a high idle and and the typical KTM engine noises. It vibrates a bit at idle -not too much-, it's a machine. The stock gearing on this bike is very tall with 16-40. Changing the front sprocket for a 15 tooth makes a big difference. It still feels a little tall like this and you're certainly not overreving the engine on the freeway. Generally accepted ideal gearing for this bike is 15-42. Anyway, this automatically solves the horrid city traffic behaviour of the engine. Shifting between 1st and 2nd in slow traffic, or 2nd and 3rd to keep it in the rev band. Stock it needs to be kept over 3500 rpm, so shorter gearing works better, especially with some minor mods to the fueling (airbox lid delete and a fuel dongle). Mine is buttery smooth now.
Is a Husky 701 quick enough for an only bike you ask? I mean it's only a thumper right? Oh yes! This bike is fast. It reminds me the most of a 90's Ducati 900SS. It may lack the smooth deep down bottom power of some other singles like the BMW G650X Moto, but it makes up for it with that big wad of midrange torque. It lifts the front wheel in first and second -and third if pushed- and feels super light. I never redline it. I weighed mine a few weeks ago, fully fuelled: 340lbs/155kg. As a comparison my FTR is 515lbs on the same scale... You feel this advantage every corner, every accelleration.
(just like the FTR) this bike oozes quality. Brakes, fit and finish, quickshifter up/down, used materials.... Ok, one exception, the speedo/dash. I can live with it, but it should have been a TFT dash, period. It's ugly, and basic.
"So, Max, if you could choose only one, which would you choose?" I honestly can't tell you. The FTR is a brute. It looks the biz, and rides accordingly, Always. Torque. The Husky however, is super sexy, superlight. Oh just never take a duo on the Husky. Actually, if you travel with luggage, choose the FTR. It doesn't even notice extra weight. I ride a lot of canyons and my buddies say I'm faster on the Vitpilen, while the FTR certainly ain't a slouch either. I think forced to make a choice I would get the Svartpilen 701 (!) to replace both yes.
Be aware that neither bikes are perfect. The FTR needs a reflash, and in time, better tires. The stock aren't horrible, but they aren't really good either. The 701 needs a different front sprocket, the airbox lid needs to be removed and a fuel dongle installed. Nothing major for both inho.
Lastly, smiles/$$. After dealer fees and taxes my FTR was close to 20k. msrp on the Vit/Svart is under 10 at the moment. Do the math :)
Great writeup!
Wow, what a weight difference, 175 pounds. And the Indian isn't way heavy like some bikes.
So similar, and so very different at the same time.
340 pounds for the 701 with a full tank... where did you weight it? That's awesome.
At home. Scale under the front wheel, rear wheel on a piece of wood to keep it level, and the other way around.
I used to do that! And then I bought two scales a couple years ago. One is used in the garage for stuff, and one in the bathroom. But I use them both to weigh bikes.
The hard part is balancing the bike vertically...
So, 25 lbs of gas, 5 lbs of oil, 5 lbs of coolent.
Sounds pretty close to manufacturers claims... man these bikes are light.
