Great!Heres a few that may help. You need to take the headlamp out to get at the 2 ties. 1 is at the top, you can see in the pic. I just put a loose fitting one back in to keep the brake line loosely in place. The 2nd is directly below the top, but near the bottom of the housing. When you cut that one, you can pull the brake line out of the channel and outside of the housing to give it more slack. You can see how it ends up. The other thing you could do is take it completely out and around the fork to see if that helps. If you want more pics, let me know., but i can't get to removing the h'light etc until the weekend most likely.
I see the top tie, that is the one I found also.
I guess that the other one is near the arrow that says relocate near to where the line comes out from behind the headlights towards the frame.
I have to dig in there and i.will sure find it.
Thank you.
