Alexandru.k_24
Hello guys,
Can someone, please, explain to me what`s the deal with the 35KW version of the Svartpilen 701?
The dealer wich I bought the motorcycle from, said that the one that i`m buying, is limited to 35KW and 150KM/H.
So what`s the deal with the power limitation. As far as speed limit, the motorcycle can easily go over 150KM/H (I rode the motorcicle more than 180km/h).
So, how to check if the motorcyle is indeed limited to 35KW? Is this power limitation over the entire rpm range? Or just on higher rpm? If indeed the power is limited, and i`ll remove it , will the low end rpm power increase? I searched online for a document about how power is limited on electronic fuel injected engines (generally speaking, not just Husqvarna`s engine), but didn`t find that much
Thank you!!!
