Finally wrapped up the garage opener. Chamberlain mini 3 button, knocked down the bike's 12V to 3.3V using a simple buck converter and then epoxied the whole thing to make it waterproof.
Mounted behind the weird little black polygon where the bike's grounds connect. Power comes from the switched accessory wire in the harness right at that location. A little poly sleeving and all done.
Also did the rear wave rotor, stock is 788g wave is 588g. Someone asked in one of the threads once how to get the rear wheel off without chunking it on the rear brake caliper - if you are on a rear stand, pull the rear axle bolt, roll the wheel forward enough to unwrap the chain off the sprocket and then take the screw out of the rearmost mount for the chain guard. This will let you flex the chain guard outside of the swingarm, then when you roll the wheel backwards right before it hits the caliper pivot it so the front end of the tire is up against the left side of the swingarm. This will give you enough room to roll the wheel out. If you don't get the chain guard out of the way the wheel can't pivot enough and you wind up with chipped rear wheel paint.
