OBD2 on 401
...Supposedly 5.5 sec 0 to 60...
(Off topic) - the 5.5 is due to the gearing if I understand correctly.
Taller gearing should lower the 0-60 considerably.
(On Topic) - the diagnostic tool I got seems to be plug and play... is that possible?
I ordered an OBDLink MX+ ODB2 Bluetooth Scanner.
My hope is to be able to record rides and then look at the RPM, Throttle, Speed, and AFR, etc...
This guy has a good video...
The guy in the video was selling KTM cables and the PID codes (RPM, Commanded F/A, Measured F/A, Commanded AFR, Measured AFR, and Transmission Gear), but seems to have disappeared. They have to be all available somewhere...
How did it go? Did you manage to get the throttle info?
Hey guys. Looking to diagnose a strange issue I had on my bike. Wouldn’t start, kept on cranking over but wouldn’t fire. Took apart the electrical thing (lol, don’t remember what it’s called — on the left side where the spark plug lead attaches too), put it back together, wouldn’t start, then waited a bit and it started. But there’s a check engine light. Sounds and rides fine. Power is there, no staling. But light hasn’t gone away. Don’t know if it will go away after a few cycles.
Was wondering about obd2. Mine is 2021, so I believe I need this euro5 connector and an obd2 app. I have obd2 Bluetooth (somewhere) so can I use any old scanner with the euro5?
I see lots of euro5 on Amazon, so I think those will work right?
Is there any particular app you guys use that interprets the codes better than others?
Rob
