New 2020 Svartpilen 401 Rider!
Hi Rob,
As far as grips go, in general, I put on Domino grips (not-heated) and had to dremmel the tabs on throttle tube down a bit.
For removal:
With compressed air the left hand grip comes off "instantly" and the throttle side is also pretty easy when you "roll it down".
Speaking of grip heaters, I was looking at these as Koso normally has good stuff.
Anyone treid em yet?
Did you ever get a set of these? Intrigued by the idea of only putting them on when needed.
10watt sounds like a low output for heated grips.
I have koso heated grips on my Vit and the lowest of 5 settings is 17W.
I've never used the lowest setting. When I use them it's always on 3-5. Which are 24, 27 and 30Watt.
