GeoKrpan
Hello everyone, and thanks for your comments and advice.
Here’s an update on the situation: I removed the drain plug, but nothing came out. I even laid the bike on one side and then on the other, but still, no oil came out through the plug. According to everything I’ve read, that plug connects to the sump, so I don’t understand why no oil is coming out. From what everyone has told me and what I’ve read, that side does indeed connect to the sump. So I’m thinking about removing the spark plug and turning the starter for a bit to spin the engine and pump the oil, then finish filling from the correct side (I've only added one quart of oil), and start it up.
What do you think?
Let me know
Evidently the sump is lower than the clutch side. The oil you poured in went into the sump. If you remove the other drain plug, oil would come out.
That begs the question, why is there two drain plugs?
Finnish adding oil and be done. Don't go Lunatic Cowboy on it.
