More Rubbers (please)
Nice.
Did they come at the same time?
Mine came 2 hours apart on two different trucks from guys wearing different color shirts...
Yeah, some guy makes this one and offers, in my oppinion, very good support.
(Also set me up with the extra parts for the 401's small axel size)
The Verdict is in!
After a  good 300km scrub in, decided I let 'er have some juice.
- New S21 Tires (Born-on-date +6 mo.) are h**** ******g better than the S21 stockers (early 2018 DoT)
-The powersliding on command is still there w/ the Added Bonus of 🤯🤯🤯 "where did that grip come from" when getting in deep.
-Emergency evasive braking maneuvers proved the ABS to be well matched to the rubber; a natural slight step out of the rear at the sweet spot of subtle engagement.
Hypersport.
So nobody else's bike can power slide... and everybody else has lower gearing and probably weighs less than me, then I figure it must be the gearing... or what else could it be?
4500 rpm and 10-20% throttle
10-20% throttle is maintenance throttle. Your rear is stepping out because of the crappy stock shock, and because you overinflated the tire.
That has nothing to do with powersliding.
The OEM recommended tire pressure is to high. Bridgestone itself recommend 2,1 bar in the front and 1,9 bar in the rear. These figures are the same for S21 and S22.
