Mirrors, blind spot detection and dashcam
Hi Tom, I was thinking on changing to end bar mirrors, but checking around I came up with your bike and I like the setup as it keeps the end bar weights. Did you need to do any modification to install them or just moving a bit the controls to make extra space?
Hi, the mirrors are indeed not plug and play with the stock bar end weights.
I've added some custom made adapter rings/spacers to attach the mirrors to the stock bar end weights.
Maybe it'll also work if you move the controls further inwards; but I haven't tested it.
Alternatively some aftermarket bar end weights with a flange to attach some bar end mirrors could be used.
Thanks Tom, that is what i thought, that I would need some spacers. As they will ill be short I guess the weight will still attach to the handlebar so it should be an easy adaptation.
Thanks again!
Yes, the stock bar end weights are quite long; you can easily add the spacers and the weights are still firmly attached to the handlebar.
