KTM 390 adv front wheel on svart 401?
photoputz83
Usa
So after around 500 miles of gravel, and sand fire road riding this lady weekend Im curious if a 19" front wheel off of a KTM 390 adv would swap into the svart fork with everything lining up (abs, break, and so on. I feel it would be a little better for the riding I typically do, and gives more options in terms of tire combinations. 2023 svart 401. 1000008874.jpg
First thing to look at is if there is enough clearance at full down travel of the front forks for the fender or wheel to clear. Looking at mine I have 4 inches of down travel and the front fender only has about 4.25" before it would hit the lower triple clamp. A 19" tire will be about 1" taller than the 17" so won't work on mine.
I would need longer forks.
Literally on the same page as you have posted about 7 posts down a member has put a KTM 390 adventure front end on his svartpilen.
He put the adv front end on with the adv front wheel. It's also a year renge compatibility question why I stated the year. I want to leave the stock fork on at this point.
I took a measurement and radius of two specific tire radius both would leave well over the required clearance. The bigger question is if the abs infrastructure would be compatible to the wheel, and the rotor. They seem to be the same but use different part numbers. Even though many aftermarket rotors state they fit moth models.
The front abs ring is for speedo reading also so it will not be accurate, I believe you can reprogram the dash for the bigger wheel but do not know for sure. Seriously, have you tried a pm to the guy who did the conversion? He states he is willing to help with info even though he has sold the bike.
Yes I pinged him a while back, and again last week.
I seldom pay attention to the speedo ascots less accurate as my gps which I typically rely on. It covers most the speedo and cluster anyway. So if its simply a speed discrepancy I'm fine with it. I did see he was able to swap the 17 stock wheel into the adv forks without issue. So if it's reverse compatible I can only assume it's the same.
Hi! New here, signed up for this thread. I have a ‘24 new model Svartpilen and I’m keen to wedge a 19” front wheel in there. Any updates?
I only saw one person adding a 19” wheel on the old model, you will be the first with the new model, the 390 adventure have a 19 inch so is possible to do but not sure what type of modification you need
the new model may be a bit different than the 20-23. im not quite sure of the changes made between the new model and what i have. I will however say that the abs issue that everyone is talking about in other threads is not an issue if you keep the difference in circumference of your specific tire selection within a certain percentage of the factory ratio. the speedometer on the other hand is guaranteed to be off. I have a full gps setup with lowrance point baja installed. so i have zero issues with this.
i went with the suspension swap and 19 front, but made a mold for a carbon high fender. so thats what is on it now. zero issues. i did notice at highway speeds that the larger wheel setup has caused a little speed wobble between 70 and 74 mph, but only in that range, and only while cruising. on the power it dissipates. swapping out the rear factory spring and adjusting the forks made a major difference here. installed a steering damper with custom bracket anyway. wasnt about to pay for the hyperpro bracket and damper assembly. installed the ohlins linear, and the custom bracket for a hundred or so less.
