kkmann
Finished up the fork spring install this morning and made a 100 mile ride! SOO much better, smooth, consistent action. Springs are Race Tech S3732 series, 0.85 kg/mm. RT recommended 7mm of preload, so that took a 30 mm spacer (they include tube spacer material, cut to fit). You can see the new springs are shorter than the original ones, which do not have any spacers installed with them. One oddity, I had to cut one coil off the new springs. You can see on the end on the table the coil diameter suddenly decreases, so it's too small to fit. Thought that was kind of weird.
this pic shows the new springs are just long enough to get to top of damper rod, but the fork cap screws on there, and so the spring is 23mm "too short", hence a spacer is needed.
Sag is excellent now at 37 mm rider sag (26% of travel), whereas OEM is was 69mm for me. This pic shows what rider sag is now.
Here's a couple pics from my ride today. You can see in first pic what the max fork travel was so far about 50 miles in, and that included pretty bumpy paved roads, dirt/gravel/rocky roads, popping over a few rocks, a 3-4 inch log, etc. So really happy with fork living in middle of travel with good consistent action. I've now removed all compression damping and I'm at only 2 or 3 clicks of rebound damping (from all the way out).
I was going to put in better seals and wipers anyway, but my right fork leg was already leaking by 300 miles so glad I had that planned. The SKF set for WP 43mm forks fits perfectly. New fluid is Amsoil Shock Therapy light (5#).
You'll need some "special" tools. I made a 45 mm hex wrench for the fork caps (left over Al plate). Fork caps are not on tight, you don't need a "real" wrench. Had to make another jam nut "wrench" for the damper rod (22mm, wrenches that big are too thick). And I had to take one of my 2-inch PVC pipe seal drivers and heat it up with a heat gun to make it a little smaller for the 43mm forks.
