First Service Due...
Any special advice?
I will remind them to enable the quick shifter.
Do they reprogram the redline light for you? Anything else I should have them check that they might miss?
When the bike reaches 1000km the shift light does wierd flashes and stuff, then when its stops, the shift light has changed to the standard values and becomes adjustable.
The redline, or rev limiter doesnt change unless you get a ecu.
I would have them check everything (except the valves) and make sure the tightness is correct on spokes, screws, bolts, etc. with a torque wrench where applicable.
