Fender Eliminator
Nice solution to avoid the melting of the turn signal. But is the position of the licence plate far enough from the tire ?
Yes. The LP bracket previously swiveled, so once in the correct position I tack welded it and slapped a little JB Weld on it to prevent movement.
Admittedly, this isn’t a good option for all US states with the bracket tucked so far under.
Hi, I received the Evotech tail tidy today. From what I can say, it's different materials for each part:
- the main part is what they call monocoque composite. It feels more rigid and heavier than normal plastic, and it's coarse to the touch. It reminds me a bit those engineered stone benchtops.
- the faceplate is made of aluminium, powder coated in black.
- the two extender brackets for the rego plate are made of plastic.
- the indicator heat shield is made of stainless steel.
Overall, it definitely feels like a quality product, I don't see how it can snap unless it gets hit seriously hard.
The only thing I don't like is the extender brackets design, my guess is that they can get loose over time.
Hope that helps ;)
FYI:
The shorter Euro LED signals arrived in the USA from the Netherlands and were installed on my Evotech tail tidy with the Evotech heat shield without any issues. I turned on the ignition key and tried the turn signals without any resistors or other "load balancers" (with USA incandescent signals up front) and all signals worked perfectly for several trials with the engine both off and running. I was pleasantly surprised to say the least. The only anomaly was the entire dash display blinked fast during the first trial but returned to normal display during each test thereafter so it seems that everything works properly, including the front signals. My ECU has not been dealer-reset for LED signals. All of my prior research indicated that resistors were necessary but I'm guessing the 2027 ECU senses the load difference and adapts. I might be wrong about that but all turn signals are working properly. ??? :unsure: BTW, the LEDS are BRIGHT! 😊
It will be constant speeds on the highway that does the damage
@Vader_MEX I’ve had the same experience. Everything was fine during normal riding at moderate RPMs. It was only when I rode on the highway for an extended period at higher speeds and higher RPMs that the heat was too intense and the turn signal began to melt.
