Electrical Accessories Install Question
jurgenk
New Hazelton, BC
Today I installed a ST2 Brake Module and an Optimate 20" lead with SAE plug for battery charging and for the air pump I carry. Also have a set of Oxford Sport heated grips that I am plan to install and seeking to avoid a mess of connections at the battery, was planning to install a Centech AP-1 as I did the same on my VStrom. Problem is I do not know where I could put it as the only decent place I found for the brake module was on top of the air box lid and there is no room there for the fuse block.
Anyone install a fuse block to theirs, or any ideas on possible locations? Watched a heated grips install video from fastidiousrestomods and he used some accessories plugs by the radiator for the connections so I could use those rather than going back to the battery or to a fuse block. The only other thing I thought about installing would be a voltmeter (perhaps with some USB plugs) as the VStrom had issues with failing stators (which happened to me) but I am not sure whether or not there is a need to be eagle-eyed on the voltage on the Vitpilen. Thanks for any thoughts.
Brad
Went ahead and installed the block where the OEM tool kit would go (the bike did not come with it); less than ideal as the battery hold down gets in the way of the powered terminals, but should work and the seat latches.
