I could get it to fit if I had the preload collar machined down 2mm. But I'm not going to bother with that and I'll just get a spring that fits.Wow, clean work! Does it not fit because it is 2mm smaller? That seems pretty close and might fit anyway?
I wouldn't change the collar either. Is this just a color change or where you trying a new rate?I could get it to fit if I had the preload collar machined down 2mm. But I'm not going to bother with that and I'll just get a spring that fits.
I don't want a white spring anyway. And getting the collar machined and the spring powder coated would probably cost the same as a new spring.
I think I'm going for a black spring.
The yellow spring is nice, but to much of a pita to keep clean![]()
I need a heavier spring rate. If it was just for the color I'd get the yellow one powder coated.I wouldn't change the collar either. Is this just a color change or where you trying a new rate?
You probably already have a good source. But if your desired spring is a 60mm inside diameter, I was able to buy a car spring for mine. See here:I need a heavier spring rate. If it was just for the color I'd get the yellow one powder coated.
hqvadventure.com
hqvadventure.com
As moezambeek said, I think that's just a case of dealers using a different brand of fluid. My clutch slave was replaced under warranty this summer. The level hasn't changed since, so I'm not worried.Hi nampus, Your clutch fluid looks white and low, is that a problem .?
Interested in which tank bag your using, and how you find it.?
And what you mount on your RAM ball.? I am looking for a workable setup to use my Tom Tom Rider sat nav on my new Vitpilen...
Cheers Jeremy
