Vintage Veloce
I sent Coober some questions. Here is what they said.
- we never test this setup, because the mid muffler is the one who is controlling the pressure and flowI am about to buy a Coober ECU for my 2020 Husqvarna Svartpilen 401.
However, I intend to make multiple modifications to the motorcycle.
I want to try running it with:
- only the premuffler deleted and the rest of the exhaust system as stock, including keeping the stock catalytic converter.
- same as the answer above. this could be even a bigger problem with higher flow on a exhaust muffler- the premuffler deleted and a new open muffler with and without a dB killer. Again the catalyic converter will be kept in the system.
- not sure if there is any solution available on the market for this, because it is a mechanical issue to run this setup and not electronic.- a fully open system with no catalytic converter, no premuffler and an open end muffler.
- for first two yes, for third no.- Can the coober adapt to these changes?
- it monitors the injection signal, because the 02 sensor is talking direct to stock ecu- Does the coober monitor the A/F mixture through the 02 sensor and make live changes (autotune)?
- yes, for all gears- Does the coober modify the fuel in both the open and closed loop sections of the map?
- The coober ecu does its own fueling, ignition, traction, for all gears and modes.Please, I would appreciate any detail you can give me about how the Coober ECU works.
