Brassy metal shavings in oil change… 23 svart 16k miles
Clovis Point
Kentucky
I’ve done all service to my 23 svart since I bought it new in nov 23 except valves, I paid a local shop to do them at about 11k miles. I replaced the clutch myself and changed oil and filters at about 13k. Well it was time for new tires and due for service so I just took my oil and filter to my local shop who’s always done good work for me in the past, what little I don’t do myself, so instead of just having him do the tires I told him to go ahead and do the service for me while it was there and do an inspection and ride it etc just to make sure i wasn’t overlooking anything and try and get ahead of anything. Well he called and said that there were “brassy metal shavings” in the oil. And that was usually a very bad sign.
I didn’t get a picture or any more details about whether they were loose in the oil or on the screen or what. I plan on running it a few hundred miles and then changing oil and inspecting filters myself.
I haven’t noticed any issues riding other than the occasional false nuetral when I’ve been hard on the throttle, but the bike does see a lot of commuter type riding. I’m making a vow to stop running it hard and prolonged on the interstate 85mph when I’m running late for something. I shouldn’t have done that as much as I have.
I know it’s not a lot of information to go off of, but what’s yalls opinion? Is this catastrophic? Is this motor destined for death soon? Should I trade it in while it still runs ? When I replaced my old clutch it was basically all the way worn out…. could this just be old clutch material that was hiding somewhere and didn’t get cleared when I changed the clutch plates? Or could I have gotten my sequencing wrong or done something wrong when I did the clutch?
No experience with the KTMs other than my 401 (no issues) but usually brass or gold colored glitter or flakes is bearing material.
I would do as you plan to do - a short run and then drain oil and inspect oil and filters again.
If still there then personally i would tear the engine down to try and find the cause.
If you don't see anything then either have an oil analysis done or just ride it some more and do another drain after a few hundred more miles.
